Originally Posted by AndyF
In your case if you just bolt it all together right out of the box then you should be in the 800 range. If you have everything touched up by pros and have the right cam in it then you could be up in the 900 range.
Andy said pretty much my opinion.
I think 820 is pretty easy with the CNC 345 heads and a cam around 0.750" lift (1.6 rockers)
