Originally Posted by racerx
Curios on why the 1050 with that much cubic in?I always thought mopars love fuel/air.
Simply because it’s what I have.
I understand it is what it is.......i just think you leavening some on the table,i had a 451" BB with a 850 that ran very lean. Put a 1050 on a/f came down engine was happy. Aren't those 440/six packs rated at 1200cfm?
For some reason 2 barrel carbs and 4 barrel carbs are not rated the same way. The 6pack carbs come out to around 950cfm in 4 barrel rated numbers If I recall correctly
