[s][/s]Gathering pieces to build my aluminum INDY MAXX RB block. Curious, and bored, so wondering what everyone thinks it will make for HP?
Here is the parts I'll be using:
INDY RB block Bore: 4.524
Molnar 4.375 stroke crank
Molnar 7.100 rods, with 2.20 big ends
Custom Diamond pistons, compression should be around 13.5:1
INDY 345 CNC heads
INDY 440-3 Intake
1050 Holley Dominator
Roller cam to be determined (open for suggestions) I do have a older Comp .750 S/S grind.
Moroso vacuum pump
Milodon oiling system
Headers will be 2 1/8 with a 4" collector
