Your installation is super nice. I see that you changed the MC outlet routing making it more logical and I assume that could only be done if both outlets had the same output. Is this correct???
I understand your safety explanation and see that it could be considered an item of failure. However, I would think the probably of such an occurrance would be astronomical. But the rule is the rule so we should build accordingly. Thank you for bearing with such a hardheaded person and providing your insight.
