lower ball joint. seen them come loose in their seat from a good bump.. the wheel try's to hop at speed. you can jack it up an grab it by the tire and lift it up and down to find them if its bad enough... smack it with a hammer on the spindle to see if it is hanging up it may be coming loose and dropping back in especially if it got bent some....
