Easy way to find out is to measure it. Probably 10 minutes worth of work if you are interested in finding out.
Twins aren't double the cost or complexity. Just depends on your goals.
Yes you can make almost any power goal with a single turbo. If at the same power level you want much faster response and the ability to hit peak boost/torque at a lower rpm on a street car, twins will make that happen.
