I just took one of these off the dyno Sunday. It was a SBF
The pros
Easy to setup
Bluetooth is great, if you had an android head unit would be awesome.
Base tune is super safe.
The cons
Limited adjustment
NO DATA LOGGING
For a guy that wants to put it in a street car, this would be good to go, set it forget it. If you were going to tune it with a turbo you are probably going to need a data recorder unless you like spending a lot of time tuning or know a guy with a dyno.
Joe
what system did you dyno with?
I have a good relationship with a tuner who has a dyno. I have spent lots of money with him and sent him lots of customers. Plus i bring him stuff he doesn't see all the time so he enjoys it
It was a Edelbrock Pro-Flo 4 on a 354 SBF, this was a engine going into a bronco, small roller cam and some AFR heads. Made 337hp @5400 with the base tune, left the shop with 380hp @5700 and a lot better BSFC numbers. had a real flat torque curve, should be a nice ride.
System was the easiest EFI I have ever setup with the duel sync distributor. saying that, none of them are really hard at all to setup.
with a turbo, i would want data logging, just noway to drive it and adjust while under boost. LOL
Joe
