You don't want the Edelbrock system for anything serious. The Edelbrock system is a black box setup where the user doesn't have much access or control. If you want a system that can work NA and down the road with a turbo then you need to start with a Holley setup. The Sniper could get you there but it might be a stretch. You most likely want a system with port injection and either a HP or a Dominator ECU.
