I remember someone here being a vendor for a variety of EFI packages but I can't remember who it was.
I'm looking at resurrecting my home made EFI intake and plopping it on the 543. I was never satisfied with my old outdated Electromotive TEC II system and would like to find a self learning port EFI system with timing control that suits my needs. I'm sure my old 120 lb/hr injectors are no longer serviceable but they'd be too big anyway. My 1700 cfm throttle body is a bit iffy but I bet I could make it work on an engine that big. I'm not sure if I'd have to dig out the old 60-2 trigger wheel or if the new stuff uses the distributor for rpm signal.
Anyway, whoever you are, poke your head up so we can talk bidness. biggrin
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
