Who is the EFI guru?
#2838171
10/27/20 11:29 PM
10/27/20 11:29 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I remember someone here being a vendor for a variety of EFI packages but I can't remember who it was. I'm looking at resurrecting my home made EFI intake and plopping it on the 543. I was never satisfied with my old outdated Electromotive TEC II system and would like to find a self learning port EFI system with timing control that suits my needs. I'm sure my old 120 lb/hr injectors are no longer serviceable but they'd be too big anyway. My 1700 cfm throttle body is a bit iffy but I bet I could make it work on an engine that big. I'm not sure if I'd have to dig out the old 60-2 trigger wheel or if the new stuff uses the distributor for rpm signal. Anyway, whoever you are, poke your head up so we can talk bidness.
Re: Who is the EFI guru?
[Re: AndyF]
#2838214
10/28/20 07:54 AM
10/28/20 07:54 AM
feets
Senior Management
Senior Management
Irving, TX
I've got an original Ford Cobra twin 57 mm throttle body as well as this monster. Those 120 lb injectors were pushing it on the street for the turbo setup but they gave me plenty of options for fueling. No doubt I'll need to step down to something in the 60 lb range. I like the FAST remote IAC and Ford TPS with the GM plug on it. Maybe I could use those with whatever system I end up with. The Holley system is definitely on my radar. I'd much rather have a system that more people know instead of the obscure Electromotive setup. It was feature packed but worked backwards from everything else out there and very few people knew how to help me tune it.
[Re: feets]
#2838259
10/28/20 10:04 AM
10/28/20 10:04 AM
Posts: 4,776 Star Idaho
67vertman
Star Idaho
Feets call, Rich at FAST Man EFI is a Holley dealer and a Mopar EFI expert.
He is only on here occasionally, so calling him is best.
My Monster are real!
Living within your means makes life pretty easy.
[Re: 67vertman]
#2838280
10/28/20 11:04 AM
10/28/20 11:04 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Holley is the easy route for sure they made some nice stuff. If your like me and need the cheap route then something in the Megasquirt Lineup is more labor intensive but has massive savings. I had to build the ECU and Harness for my setup but my $$$ per feature is incredibly low and reliability has been perfect over nearly 6 years now.
I would go with the smaller throttle body, its hard to modulate small amounts of throttle with a big single blade like that accufab but it won't be hard to swap between the two to test them out.
68 Barracuda Formula S 340
[Re: 67vertman]
#2838409
10/28/20 04:21 PM
10/28/20 04:21 PM
Posts: 513 Springboro, Ohio
Hollywood
Springboro, Ohio
I second the vote for Rich. He really knows his stuff and did a great job on a 6.1 Hemi with 8 stack injection that I built. Rich Nedbal-EFI ExpertFeets call, Rich at FAST Man EFI is a Holley dealer and a Mopar EFI expert.
[Re: Hollywood]
#2838634
10/29/20 07:47 AM
10/29/20 07:47 AM
feets
Senior Management
Senior Management
Irving, TX
He is only on here occasionally, so calling him is best. Very nice. I spoke to Rich yesterday.
