I know this is an old thread, but I'm looking for something available that would bolt to the rear leaf spring U-bolts under shock plate .... for hooking up to trailer straps for open trailer towing. Anything from a vendor available?.. for my E-body?
I'll be changing my leaf springs very soon and this could be the time to do it. Wrapping short straps around my axle didn't seem to be very good (diagonal from behind the rear brakes using ~24" straps).
Also, the factory rear frame anchors have their holes a bit too small, but snap hooks could be used there.
I wonder which is better... hooking up the axle.. or the rear chassis?
I don't tow much.. but intend to start up again for 2021... towing maybe 6x per year midwest.
T/Anks ahead.
