I have a few different input shafts to choose from so I'm trying to decide which is the best to use. Are the later generation with the three sealing rings better than the earlier two ring style? I'm not sure I understand the oiling difference. The early ones have a hole in the shaft but the later one doesn't. So there must have been a change along the way but I haven't found any reference yet to what else changed.
