ok-----its the same rules--you can use a cummins or v10 and you can change the input shaft bearing/ retainer-------or you can use a dodge gas nv4500 stock---you can only use the late chev and you have to put the dodge gas input bearing /retainer--- the chev 2wd has an old school transmission brake on the tail.....
