I never found the need for them.. where a failure accures is the carrier.. thats why I went to the alum MP carrier its much stronger with thu bolt for the caps that carrier dosent let the ring and pinion separate like the stock one
.... I’ve got picts on my phone that says otherwise! At least when the aluminum one lets go you get style points!
