Originally Posted by mccannix
Width of the 67 C-body dana I removed was 61 5/8 drum to drum and is regarded as such.
I do know it was a direct fit into an E-body.
E-body dana width drum to drum is 61 3/4.
Spring perch distance center to center of both the E-body 9 3/4 dana and the C-body 9 1/4 dana is 46 " for both.
As I stated, it bolted right into an E-body
But did you check the pinion angle?
The gist of this thread is that the OP cited a FSM that is not body specific. The quote from the FSM is relative to C-bodies only.
The INTERNET, the MISinformation superhighway
