putting a 1967 b-body together. set the front end height 1 7/8 -2". turned the rear cam bolts all the way in both sides. front cam bolts all the way out both sides. Caster is great 3 -4 deg. pos. both sides, camber is way out approx 4 deg. pos also, didn't pay a whole lot of attention to the exact number wheels were leaning visibly. Start to turn front cams in to bring camber into range. I cant get both sides equal. best I could do was split differences. ended up with -.5 deg.caster both sides but get 1 pos. degree camber on the left and 1.5 pos. degree right in camber if I bring the camber down I get farther on the negative side of the caster. any thought or opinions?
