thanks for the info thats good stuff. should be nearly identical to what im doing.
I moved the detailed info over to the LX forums figured it may be better place for it, however ill keep this post up to date with latest pictures.
I have gotten the cooling and power steering systems up ended up drilling the threads out on the power steering pump from the magnum and bolting it where the idler pulley went. Allowed better clearance for the radiator hose.
I also got the wheels and tires in. us wheels series 66 15x14 and mickey thompson et street s/s 31x18R15LT
