I found out the hard way that not using a baffle under the vacuum fitting on my new motor caused a lot more oil being sucked into the tank on every run, it would fill the tank up in less than 6 runs
![puke puke](/ubbthreads/images/graemlins/custom/puke.gif)
![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
I swap the old valve covers onto the new motor and cure that problem
![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
Using the baffle under the fitting resulted in almost pure moisture with in the tank and very little oil
I think the oil droplets being slung off of the rocker arms are being forced into the fitting and up the hose under suction and not being given a chance to drop back into the heads, the baffle stops that
![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
