Originally Posted by Cab_Burge
How is oil and vapor being drawn the other way? Especially under acceleration work shruggy
Cab, what i meant was that, as far as i can figure, ia baffle is not really needed since the crankcase is under vacuum and being pulled into the pump. So oil won’t be pushed up the fitting, like if the crankcase was under pressure and vents to any openings. This is what i surmised, but correct me if i’m wrong on my thinking, please.
1.50 60Ft. , 10.75@ 127MPH Hauling 3900 LBS.
