Originally Posted by JD340
Originally Posted by Grizzly
The shifter will work as long as it has the same hair pin setup as factory.
Putting an OD in is a little more involved with modifying the rods and transmission levers.
If you know how to weld it's easy, it's a bit of a pain though.
Are you putting an OD in a B body or putting the shifter in a truck with OD?
Hoping to use the shifter in my truck. My factory shifter is worn and sloppy, I figured an upgrade to the comp plus would tighten things up considerably. PLUS, it comes with the pistol grip shifter I've been wanting to add as well!
It will work but you may need to make the 3-4 rod longer shruggy
Gus beer
64 Plymouth Savoy
493 Indy EZ's by Nick at Compu-Flow
5-Speed Richmond faceplate Liberty box
Dana 60
