Originally Posted by MR_P_BODY
That would depend on the clearances.. mainly the pump and the oil level... I use to run a fairly tight radius on the
hump to keep the air volume down to a minimum and try to keep the hump close to the pump(again less air
volume)
wave
Hi Mike,
I do not have hump in the feedline to the pump, as one of the header tubes is very close to the AN -12 hose. I use a 45* fitting at the pump, and right angle at the pickup..
That is why I was asking if I would be better off to run the Accumulator to the fitting on top of the Indy filter adapter, instead of running an AN -6 hose to the back/top of the block.
Thanks for any advice, Mark
