Originally Posted by lockjaw-express
Sammy,
I looked at the Indy Billet oil pump today...the pump looks to be cast Iron (Indy part) and the cover is two piece. There is a cover bolted on the pump, then an adapter for the oil filter. On the top of the Oil filter adapter there is a single 1/4" pipe plug on the top. I will call Indy on Monday to find out if my accumulator could or should be plumbed into there???
Mark
Yes that's where I had mine on.
I wish I never switched from Indys pump setup.
Never an issue.
-10an line to the 1/4 port.
Sammy,
Attaching the accumulator to that port, would it prevent the pump from losing the prime? and still pre-oil the bearings?
Mark
Mark. I have my accumulator on a solenoid switch.
When I'm ready to turn off the motor, I rev up the engine to get maximum oil pressure, then turn off the switch.
It will hold my75psi till I turn the switch back on to prime the engine.
