Originally Posted by fast68plymouth
Does it have cal tracs and SS springs?
If so.......Try taking the bars off.
I'm actually running 3200 lbs SS springs with a properly adjusted slapper bar. Without the slapper bars, the car was bending the front passenger side spring segment and a pinion snubber basically stops any movement of the rear suspension on the open road resulting in a brutally harsh ride. The spring rating of 3200 lbs is lighter than the car by at least 500 to 700 lbs for better ride quality.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's
1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
