Question: Assuming two engines make the same peak HP, what's more stressful on a bottom end? a) 7500 RPM with a 3.75 stroke (451) b) 6500 RPM with a 4.25 stroke (511)
Not meant to be a quiz; I'm curious about what's more likely to put the hurt to a marginal block.
