Maybe. You have lots of compression so that will help. Cam seems too big for that size of engine so I'm not sure how well it will work. With that big of a cam you might not build enough torque in the mid range to carry the numbers up high. You'll just have to give it a try and see. You might end up needing less duration and more lift to make big numbers. Good luck, let us know how it runs.
