Using their numbers, the standard version CAN get UP TO 250 miles per charge. We know how the "can get up to" goes.
But you can get a 2x motor version, and a 3x motor version CAN haul UP TO 14,000 lbs.
A single motor gets 250 miles from a charge.
Then a 2x motor should get 125 miles from a charge.
And so a 3x motor should be able to get 83.33 miles from a charge.
I suspect there is probably a speed limitation to get the full range of mileage from the charge, I wonder what that might be? 30 mph? If its 30 mph, would 60 mph cut the distance in 1/2?
Rhinodart, maybe you could get from your home to the Rockford shop before you needed to sit 8 hours for the recharge.... I can see you now standing in line to get your hands on one of these babies!
(We need a rolling on the floor laughing smiley) Gene
