seperate the steering column pull apart connector & ohm the turn signal harness with the stalk in neutral/up/down (www.mymopar.com will have the colors). confirm each light is grounded well. clean all (turn signal related) connections/terminals. Sorry nothing definite, probably just have to dig & clean till it clears up
