See the air cleaner set ups and the air dam under the car are things im talking about, those are cool and they dont take more then a few bucks and some genius designs, ive thought about those but i cant find a cheap hemi scoop so itll have to wait. So on the air cleaner set ups do you just measure out the bottom of your hood where the scoop is then make a pan and use foam to seal it?
