The mr gaskets have a lot bigger bore than the mopar performance ones did or the fel pro 1008 so no significant compression gain from the mr gasket. If however you went from the 1008 to the mopar you could gain around 1/2 point depending on the rest of the combo.
My problem with nitrous has always been that I can't refill it for $2 gal at the gas pump.
