3,500 pound RR Stock type 6 pak hood 511 tall deck, filled block 727....footbrake Dana...4.30 iirc Split leaf and caltrac Rancho 9 way Under .620 solid roller Bracket duration 1.5 rocker Under 13:1 compression 110 fuel STD port Super Victor intake 1050 Dominator, non HP body 9" convertor Swinging Milidon 2" to 2-1/8" TTI 12" collector extension 32* or 33* timing 6al
