i need to come up with an in tank electric fuel pump for my charger.
it already has a 3/8" feed from the factory sender unit, and a 5/16" return.
as i have a new stainless tank, i will be fabricating something, using the sender hole as is, and working through the filler neck hole.
also, i will be starting off with a carb, and in the future, going to EFI, so i will have to have a pump that will supply adequate pressure and volume for that, but able to regulate down to 4-6 [?]psi for my initial thermoquad carb.
if i get a pump that "should" support 600hp, [will never be that, just want to insure adequate delivery] what would be the best pump for that ?
a small walbro perhaps ?
i would prefer to go intank if possible without cutting an extra hole, so this will be "building a ship in a bottle" project.
THANKS MUCH in advance !
