Originally Posted by Cab_Burge
I would try tightening the air door tighter until it doesn't bog anymore when it opens twocents scope
I will try that tomorrow.
I did disconnect the secondaries and took a ride. Usually around 55-60% throttle is where the bog/lay over starts. Got to 80% throttle before it started this time.
Another weird thing that it always does. When taking a left hand corner there is a skip or miss in the motor like the fuel supply was pinched. Just one skip, not a series of them.
My Dad always told me, when setting goals " avoid disappointment, aim low".
