Not that i’m experienced enough with sonic testing or owning a large sample of blocks, but can those numbers be right?? I’ve never heard of bore thickness in the .600” range. Or even .500”+ for that matter within a stock block. I could be totally off base, but i thought some of the afternarket blocks are proud to have .300”+.
1.50 60Ft. , 10.75@ 127MPH Hauling 3900 LBS.
