Re: Do these bore #'s look good?
[Re: hudsonhornet7x]
#2682558
07/29/19 10:57 PM
07/29/19 10:57 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
What is the bottom number on #6 on the outside of that cylinder? If it is above.200 I would be glad to use it in a heartbeat How far are you wanting to bore it out to,+.030,+.040, +.060 or what size?
#2682574
07/30/19 12:38 AM
07/30/19 12:38 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Not that i’m experienced enough with sonic testing or owning a large sample of blocks, but can those numbers be right?? I’ve never heard of bore thickness in the .600” range. Or even .500”+ for that matter within a stock block. I could be totally off base, but i thought some of the afternarket blocks are proud to have .300”+.
#2682626
07/30/19 09:44 AM
07/30/19 09:44 AM
Posts: 17,869 S.E. Michigan
ZIPPY
S.E. Michigan
Just my humble opinion.... these numbers seem too good to be true.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2682634
07/30/19 09:58 AM
07/30/19 09:58 AM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
Just my humble opinion.... these numbers seem too good to be true. I can tell you there are double what the 400 that was in my daughters 76,D100 are
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
#2682707
07/30/19 01:00 PM
07/30/19 01:00 PM
ZIPPY
S.E. Michigan
The numbers are thicker than a World block.... I don't want to be negative...so I'd say...Hey, anything is possible! Except that...that isn't
Rich H.
Esse Quam Videri
#2682820
07/30/19 07:10 PM
07/30/19 07:10 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Absolutely not good numbers at all. Either they are fake, or someone doesnt know how to calibrate their sonic tester. You first do whats called a " probe zero", then you calibrate it to a known and measurable thickness.
RIP Monte Smith
