Throttle shaft slop is not usually a problem unless the carburetor is a high mileage unit or someone used throttle springs with too much pressure causing the bores to become egg-shaped, typically most evident on the driver side. This is why my process includes re-bushed bores with every carb, its a simple procedure to eliminate any potential slop issues.
