Originally Posted by BradH
Originally Posted by Stanton
Originally Posted by fuseable
I am using a .005 stainless shim between the gear and bushing. I started thinking about a shim and posted here , another member replied and has been doing this for some time and has not had any issues using one. I cannot remember the other member. I put one in in Feb. I haven't had the gear out to check it yet. My last Milodon bronze gear (prior to .005 shim) and the bushing where eating each other up. A place called the Shim Shack made up the shims for me, cost was not to bad, as I remember I had 6 run.
Well, I submitted a request for a quote and they came back at $10. each.. Not money well spent in my opinion when a 25 cent Torrington washer will do !!!
Bet it would cost me more than $10 to have someone machine my gear to use the $.25 washer, since I don't have the equipment to do it myself.
Maybe you need to make some friends !!! smile
