When I sell my wire around cables, which includes a fusible link, I suggest leaving all the OEM wiring in place if the bulkhead is in good shape.
I'm not a fan of ammeters and bypass/take them out of the system. I run a voltmeter instead. Want to run an ammeter, have at it.
8 gauge wire, which is the smallest wire that I sell. Hides really easy in the OEM harness tabs
