I might not be a "pro" that has assembled thousands of engines but I can assemble ones that don't leak.
I also do not use RTV of any kind, or the right stuff. It's called attention to detail and if your pro's attention is insufficient to seal an oil pan, which on a B/RB is the easiest in the world to seal, what else escaped his attention?
