Probably easier to keep hauling the car all the way to the track, hope you get a couple of good passes in...... look at the time slips and data logs......... and wonder why it’s not doing what you think it should.
Instead of a day on the dyno ...........where you could make 15-20 pulls and have a bunch of data to look at ..........that isn’t compromised by track conditions.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
