This should work, no?
THERMOQUAD SPACER
Not sure how that is better than a FEL-PRO 60273, which is 1/6th the price. However, either one will affect your stock choke linkage setup since they will space the carb up more.
Agreed Sniper, seemed quite expensive.
The FEL PRO you listed seems to be only the base gasket though, not a spacer.
In 71 the TQ base gasket was thin. In 78 it was about 1/4" thick same as that spacer, that's the Felpro 60273
Ok gotcha.
Forgot to reply about the choke linkage comment.
So will the spacer not work with it then?
Mopar
Or
No
Car
