I've had that happen before and it was heat soak. It boils the gas in the carbs causing it to flood the engine. If it happens hold pedal all the way to floor and crank it. If you let go of the starter to rest don't let up on gas pedal so you don't add more fuel to the problem. It takes some cranking but should start without starting fluid.
