Not sure how that is better than a FEL-PRO 60273, which is 1/6th the price. However, either one will affect your stock choke linkage setup since they will space the carb up more.
Agreed Sniper, seemed quite expensive. The FEL PRO you listed seems to be only the base gasket though, not a spacer.
