I’m not sure what I’m supposed to be looking at that would make the light bulb turn on......... but I doubt from the factory they came with an open gasket installed between the carb and manifold. Not that it shouldn’t work fine....... just that they also worked fine without it.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
