[/quote]
Get a pedal commander, it will fix that issue in 2 seconds.
https://www.youtube.com/watch?v=En8K76-C7sE [/quote]
The pedal commander simply changes the sensitivity rate of the throttle. Basically tells the PCM you're at 100% throttle when you've only travelled 50% with your foot. This is no different then what you can do with any tuner bumping the throttle % up. But the problem is not there, it's in the PCM itself.
The PCM has quite a few safety and drivability delays built into it. These are NOT parameters that a regular tuner has access too, only an FCA development PCM unit can take these changes.
But even at that... the cars still aren't good enough to foot brake off the bottom bulb unless you're guessing in between lights (or going in way deep).
