Just Wow.....does the other makes(GM,Ford) muscle come with the line lock/trans breaks)?
I'm wondering if you could activate the tranny brake before the tree comes down?
seems like a lot to do between pre-stage and stage. Wondering can you manual shift these trans?
Not sure if it will let you hit the limiter on shifting. The trans. brake was not explained correctly in the video. PRE-stage, pull both paddles back, bring the R's up and STAGE, let go of the one paddle and take your foot off the brake. Go on yellow...
