This set of Jesel rockers have no oil holes for the rocker tips or axles whiney
They came with the heads along with the spray bar covers, the ratio on the box says there 1.55 ratio shruggy
I hope to race the motor this weekend at our local 1/8 mile track with out the spray bar covers do to no provision for the vacuum pump fittings, yet whiney
I'll look at the rockers and valve springs after the first day and decide if I will run it the second day luck
