Divide the area of the line i.d by the number of holes and that will be the MAX area of the holes. Now use your math skills to convert that to a diameter and voila, you have your drill bit size. If the total area of the holes exceeds the area of the line size the oil will just dribble out, you needs the total area of the holes to be smaller to "squirt".
