I use the Pioneer brand, never had a loose ones yet (100+ so far)with no cam installed and driving it into place with a stock iron gear and shaft I have seen wear marks on the shafts after running the motors on a engine dyno with a Milidon gear and shaft and the Milidon cast aluminum oil pump using their two external oil line and swinging pickup system
