I bought the tool to remove and reinstall the bushing. One thing most people overlook is to fill the bushing opening with redline synthetic gear oil and squeeze it between your finger and thumb until it oozes out through the pours of the sintered brass. Then press it in and burnish it with the tool.
Another idea is to use the treated steel gear on a new cam. If you can't do that, have the gear cryogenically treated .and coat it with synthetic disc brake grease.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
