Originally Posted by 67autocross
Most of the small block builds around here are pump gas stroker 408-416 inch jobs with a max at say 11:1 that make under 600hp...after that they jump up 700hp and up stuff with big heads and aftermarket blocks. I don’t recall anyone I know really building at 12:1 stroker with a stock style head, this is most likely because it would need race gas and not really make a bunch more power....I’m going to see how this pro maxx stroker does on the dyno before I buy a top end for my stroker.
A 12.5 to 1 stroker will ET a lot better than than a 10 to 1 stroker.
I could care less about having to run race gas. It wont be a daily driver. Might run 100 gallons of fuel through it a summer. Thats700 bucks. Thats putting around town and racing maybe 8 outings a summer
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight
418 BPE factory replacement headed stroker, 565 lift solid cam
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
